乾龙盛产品用户交流区QLS-HiFi产品及技术专区QLS-HiFi产品及技术相关 → microusby cable for 390
  共有22429人关注过本帖树形打印复制链接
主题:microusby cable for 390
Maksim
等级:新手上路 帖子:5 积分:96 威望:0 精华:0 注册:2021-1-11 1:34:44
microusby cable for 390  发帖心情 Post By:2021-1-12 5:41:43 [只看该作者]
Hello.  what should be the cable to connect the phone as a carrier. No phone and no cable are connected even via OTG.
  发帖心情 Post By:2021-1-12 10:15:33 [只看该作者]
Hello, What brand of mobile are you using?
Maksim
  发帖心情 Post By:2021-1-13 0:27:34 [只看该作者]
Samsung note 10 +, Blackberry Passport.  QLS 390 can work as an external DAC?
  发帖心情 Post By:2021-1-13 10:17:08 [只看该作者]
Maksim
  发帖心情 Post By:2021-1-15 2:50:27 [只看该作者]
Thank you very much.  Samsung helped, but not with Blackberry((
  发帖心情 Post By:2021-1-15 10:21:11 [只看该作者]
I don't know about the Blackberry Passport phone at all, but if you can find its data cable (output is micro usb or to usb connector adapter)
(is not a charging cable, is Data Transfer, Function Connecting), chances are that it can be used directly.
Maksim
  发帖心情 Post By:2021-1-15 12:08:04 [只看该作者]
usb works, it doesn't work.  The player as a transport is not correct in timbre balance.  Firmware except app is not installed.  Let's have a normal firmware, so that everything would work at least like 361, otherwise I'm damn it !!!!!  upset sovsnm.  You are a good company, what is your problem?  I, in order to buy your 390, even sold ibasso max.  You should be fine.  You gave everything to the sound !!!.  Why is it buggy and not playing.  I really hope that in a week you will make the best firmware.  It's within your power!  I really believe in you)) My ears do not play at all without your recharge.  With great respect, Bionic!)
Maksim
  发帖心情 Post By:2021-1-15 12:52:44 [只看该作者]
Here are my ears, Bionic)
  发帖心情 Post By:2021-1-15 20:26:21 [只看该作者]
I'm very sorry, I don't understand what you mean, what doesn't work?
